Lend me your eyes, oh posse!
I left work this afternoon, turned a corner (albeit somewhat sideways?) and went up the hill, never more than 65kmph... speed camera truck on opposite side of the road, on the side where traffic would be going downhill.
It flashed as I was coming up to it :D
Do you think its possible the guy inside set it off manually to get my plates etc?
OR is it more likely someone going the other way was speeding at the same time? Which side of the road/which way do they face?
EDIT: Yes, dumb, I know... shouldn't be doing stupid things.
Edited by mosquitocoils
They for the side of the road they're on - you should be fine.
OR - they take photos of the traffic going the same direction that their camera is pointing (usually the same side of the road they're on - but I've heard of some vans that have 2 cameras)
But I still think you'll be fine.
why did u want me to go home?
well... my car is driving like a charade, really need to put that goo on my coil pack. I was supposed to go to Jason's place to do it... but he's disappeared off the face of the earth... and I don't have sockets :D
Hmmmmm thanks for that... yeah I just hate the feeling in the pit of my stomach right now :D So dumb hahahaha ah well
well... my car is driving like a charade, really need to put that goo on my coil pack. I was supposed to go to Jason's place to do it... but he's disappeared off the face of the earth... and I don't have sockets :O
What do you need sockets for? Removing crossover pipe + coilpack cover etc? Or are you without coilpack cover? If you're without then you just need a phillips head screw driver... although you've probably thought of that already hahaha
unlucky. I can probably give u a lift if you need - call/sms me if you do as I'm about to p*ss off
It's driveable (just) so don't need a lift, thanks though!
removing strut brace, crossover pipe and blow off valve.
got allan keys and screwdrivers. Thought about trying it with my shifters, but it'd probably take me all fkn day
True where do you live? You can swing by mine and do it in my driveway if you want tonight?
That does not sound good
so, i finished work not too long ago, now im chillin here, just assembled my new snap-on air compressor, its a little oversized to say the lest.
I need a 15amp power point wired into my garage now......
It flashed as I was coming up to it :blush:
they can get you on both sides of the road. old boss got done by one with me in the car. camera was on the other side, flashed as he went past doing 70. got the fine two weeks later.
good luck. hopefully it was for someone on the other side.
That compressor looks bad ass :blush:
Don't the cameras have to point the same direction that the car is travelling though?
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
