so sick of false promises :down:
Why does work pickup so much in the morning... Kingsford smith drive near the gateway is FLOODED and one lane closed. Yay peak hour.
in other news - Franga33 has this avatar and it made me lol:
WIN!
You know it. Fun fun fun.
Crisis averted. Brisbane didn't flood :down:
Just bits of it did.
needs moar floods
so sick of false promises :D
Thats what she said
nah money is a bit tight at the mo... have to wait until tax time
Yeah bring on tax time. Can't wait to get some money back this time instead of an epic bill :)
P.S. Morning mangs
yeah boi
thanks :) just let me know whenever is good for you. I need to take it from Stafford to Aspley. I have ratchet straps if needed
annnnnnnd - opinions on this? Would it be a good enough temporary solution/trouble shooter to make sure I'm holding boost ok? I really don't want to pay much for one because I just want it for a couple of comparisons. So basically... I don't need it to live very long, just need it to be somewhat accurate.
thanks :ninja: just let me know whenever is good for you. I need to take it from Stafford to Aspley. I have ratchet straps if needed
This arvo? Tomorrow arvo? Saturday?
I has a mechanical boost guage in the ute if you want to borrow it for a bit. I need it back to put on the mower at some stage but :)
This afternoon works fine for me. What time are you thinking?
Would take you up on the offer if I knew how long I was going to be tooling around with it, don't want to wind up taking it out of the ute then not using it for 5 months and giving it back and needing it 2 months later lol. I want to get one so I can install it and test my boost for now. But down the track when I get my front mount I want to get the boost wound up a bit too, and just want it in there to check it holds boost alright after driving it around a bit. Also want to see what happens after I let Dan turn my blow off valve into a flutter valve, and (before Dan plays with it) compare it with my other blow off valve(Thanks again Ravi!!) to see if one builds boost faster... it seems to.
I should be home sometime around 4-4:30 ish. Assuming my housemate hasn't crimmed the XF, any time after that.
Furry Muff.
In that case, I'm sure that one you posted will be fine. It looks to be similar to the saber/autogauge ones, so Tas will give you sh*t because they aren't defi, but Tas is a brand wh*re. They should be reasonably accurate and will do the job.
As I said when you were here, just blank the f**ker off. If it f**ks your turbo, then you've got an excuse to upgrade :)
I've got a custom blanking plate made from quality billet steel with a high-temp ceramic coating you can use for a bit if you want. See the pics. Had it on mine for a while but got over it hahaha.
:ninja:
Furry Muff.
Well, just gimme a call or whatever and let me know the plan of attack :cool:
I don't like the Defi ones anyway. I think they're ricer and are made with 7% synthetics and 93% gay. So he can give me shit about NOT putting rice on my car, I don't mind :)
As I said when you were here, just blank the f**ker off. If it f**ks your turbo, then you've got an excuse to upgrade :wave:
And as I said. That's all well and good if you can afford to buy a new turbo when it shits itself :ninja: (plus I haven't the faintest idea how to change the thing, so I'd have to pay for that too)
Yeah true, I can't say I have money to do it either. But putting a direct replacement on looks pretty easy, I've seen all the tutorials and a friend has explained it for me and yeah, pretty easy.
But flutters = epic. Nuff said.
Having said that, best option is to not f**k the original one anyway hahahahaha you're right.
Well, just gimme a call or whatever and let me know the plan of attack :wave:
righteo
<3
And as I said. That's all well and good if you can afford to buy a new turbo when it shits itself :cool: (plus I haven't the faintest idea how to change the thing, so I'd have to pay for that too)
It won't wreck your turbo.
Changing turbos is easy
<3
:ninja:
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
