Sweet well looks like I'll have to hurry up and get the gtr into the shop and get the goodies on it then head straight to chappel hill on thursday night. Hope to see you guys there sometime soon when my cars back
farken carnt of a day today
property damage and getting assaulted at work. i wonder what the rest of the week will bring
someone assaulted YOU? :)
agreed - who in their right mind would take you on, especially when you have me on speed dial... ha ha
no but seriously wtf!
it was a 14 year old, 55kg aboriginal kid at work, and he only did because he knows that i am not allowed to crush him to death, or i will lose my blue card.
no serious damage, but fark i was pissed off.
Getting the timing belt done with adjustable cam gears as well as a n1 water pump, harmonic balancer, crank and cam seals. The clutch is been replaced with probably a twin plate at this stage to handle the up and coming upgrades, probably with a lightened flywheel. Also doing split fire coil packs, maybe hks twin power system and installing a vipec ecu all before it gets dyno tuned. So should be good for approx 300 at all four wheels.
From there I will have to look at upgrading the fuel pumps and turbos all before the intercooler is changed out as everything is stock
Edited by 32vspec2gtr
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
