You asked me:
Dick In Ass, Gooch f**ker?
I'm quite comfortable being able to sit down without a hemorrhoid doughnut, so I said no thank you :)
You must have dicks, asses and gooches on the mind.
DIAGF = Die In A Grease Fire.
done ages ago never bothered to pick it up.. lol...
neg just new under body parts..
trying to find those air ducts that 32 33 and i think 34 gtr got... next to the rod ends.. otherwise i will have to fab up some..
Wreckers? They would be fairly easy to make. Fibreglass ftw.
Mmmmm I know what you mean. I think I'm gonna have to be careful once I land a job to NOT go stupid on little expensive pieces. The only money I'm really prepared to throw at the 32 is a paint job, and an engine transplant (and related items. fuel pumps etc). Apart from that I have to start saving for my 34 once I'm working again!! :)
ENGINE CONVERSION!
ZOMG RB26
i <3 JOHN
My money is on a Civic or FC
idk, possibly an evo (if still serious about time attack)
all 13bs are suited to rebuilds lol :P
lolz! quality post
No, I am not going to hunt back through and find it for you, but in the classifieds somebody had a set of the inner guards with the ducts for sale. I think he was in Melbourne.
ENGINE CONVERSION!
ZOMG RB26
i <3 JOHN
Evo is a good shout as well mmm...Anybody want to get a betting pool started?
lolz! quality post
<3
You just be incredibly.... flaming :P
lmao nice :)
If I do a conversion, it'll be an RB25, or a VG30 twin turbo.
*facepalm
i was giving you big love there bro and u just killed me
are you going to strip the car and get all gtst running parts?
awd car = awd motor, hence rb26
like im sure it is possible to do it with a gtsFO - but i mean wouldnt it be easier to sell the FO and get a cheap gtst and do the conversion, or buy one with the conversion already done?
*facepalm
the stagea RB25 fits easily in a GTSfo
I have a soft spot for the 6s. One of the other cars I was looking at before I bought the GTR.
yeh 6s have always been my fav too! i wanted an evo 6, then wanted a gtir, then r32 lol
still want a GTiR - maybe when i finish uni, itll be a rad little car - stockish motor and and cronic suspension
VQ35DETT over a VG tbh. If you were going to do something awkward like a VG you would have to be mad to go past the VQ engines.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
