I'm afraid this proposal is unacceptable. Allow me to point out the following:
-She is too young for skins
-She is too white for you
-I have a black belt in being awesome
Therefore, she is mine. QED. TFC.
If you have any doubt as to the validity of this argument, please see Rule 1.
That is an interesting argument. However, I put it to you sir... :cool:
you know the rest :P
No german club for me. Mates 21st tomorrow so I will be getting wasted there. :blush:
back to the m-spec debate,
im 98% sure that there is no such thing as an "un" m-spec r32, im pretty sure it was just a smart marketing scheme implemented by nissan when they first released the r32 gtst
Give the man a prize :blush:
For those who are interested in the legal theories that i was talking about at the meet last night here is a link that properly explains the 'Chewbacca Defense' :blush:
EDIT: Lol linky http://en.wikipedia.org/wiki/Chewbacca_defense
o rly? maybe if they're nice and common it's ok to cut into mine then... hmmm
Edited by Isola
Ya Rly. All GTSTs were Type Ms. Chop that shit up :blush:
