I'm afraid this proposal is unacceptable. Allow me to point out the following:
-She is too young for skins
-She is too white for you
-I have a black belt in being awesome
Therefore, she is mine. QED. TFC.
If you have any doubt as to the validity of this argument, please see Rule 1.
That is an interesting argument. However, I put it to you sir... :cool:
you know the rest :P
No german club for me. Mates 21st tomorrow so I will be getting wasted there. :blush:
back to the m-spec debate,
im 98% sure that there is no such thing as an "un" m-spec r32, im pretty sure it was just a smart marketing scheme implemented by nissan when they first released the r32 gtst
Give the man a prize :blush:
For those who are interested in the legal theories that i was talking about at the meet last night here is a link that properly explains the 'Chewbacca Defense' :blush:
EDIT: Lol linky http://en.wikipedia.org/wiki/Chewbacca_defense
o rly? maybe if they're nice and common it's ok to cut into mine then... hmmm
Edited by Isola
Ya Rly. All GTSTs were Type Ms. Chop that shit up :blush:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
