Lets not get ahead of ourselves, theres still 52 pages to go...
Even averaging one a day that won't take us all year though...
Do it, you skirt
Maybe... it's not like I'll wreck my tyres :blush:
Now THAT is someone excited to claim a page!
You know it!!
DIAGF
Yeah, go die in a gay fire. In Indooroopilly lol
what happend to all you flakes ..... :blush:
waiting .....
still waiting .....
peace out moles, im off to the ranga mobile, or maybe the lounge ..... :D
Will try and make it over after the gym tonight so around 9-9:30ish...
I also this week realise I want an S15...
Let the flames begin as I rot in hell :blush:
they are like 100x better than a r33, good choice!
Can still crash on the track :D (EDIT: But yes, I agree with you wholehartedly. Keep it off the street)
Yeah but at least your only going to take yourself out in the worst case and besides you don't have a big ol power pole sitting there smilling at you when you loop it and suddenly find yourself sling shotting across the road lol
Oh and by the way they can get you for driving a car in a way to create excessive noise. Trust we got done in a mates impala in the city when we punched it off the lights. its like a 300 fine :blush:
no flames from me. I like the S15s.
Would have flamed you hardcore if you said you wanted an S14 though. I would have started a collection to get you a handbag for your birthday that would match the paintwork.
x2
Hey bunta how do you find your npc clutch? is it the 1000hp one?
went into the panel shop this arvo.
He can fix my front bar :blush: Yay.
He reckons due to the problems matching metallic paint, and the small amount of damage on the guard, it will be better to repair the old guard. That way he can blend the paint so there is no difference at the edges where it meets other panels.
So, bit of a waste of time rolling that guard, but now I have a spare rolled guard I guess...
Anyway, it should all be done next week sometime :D
Got my headlight back too, its come out really well:
x2
its a bit of a bitch, but hey if you dont stall at least once a trip its a girl clutch. Its no worse than say an os giken dampered twin and much better thaqn the old nismo tripple!
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
