Lets not get ahead of ourselves, theres still 52 pages to go...
Even averaging one a day that won't take us all year though...
Do it, you skirt
Maybe... it's not like I'll wreck my tyres :blush:
Now THAT is someone excited to claim a page!
You know it!!
DIAGF
Yeah, go die in a gay fire. In Indooroopilly lol
what happend to all you flakes ..... :blush:
waiting .....
still waiting .....
peace out moles, im off to the ranga mobile, or maybe the lounge ..... :D
Will try and make it over after the gym tonight so around 9-9:30ish...
I also this week realise I want an S15...
Let the flames begin as I rot in hell :blush:
they are like 100x better than a r33, good choice!
Can still crash on the track :D (EDIT: But yes, I agree with you wholehartedly. Keep it off the street)
Yeah but at least your only going to take yourself out in the worst case and besides you don't have a big ol power pole sitting there smilling at you when you loop it and suddenly find yourself sling shotting across the road lol
Oh and by the way they can get you for driving a car in a way to create excessive noise. Trust we got done in a mates impala in the city when we punched it off the lights. its like a 300 fine :blush:
no flames from me. I like the S15s.
Would have flamed you hardcore if you said you wanted an S14 though. I would have started a collection to get you a handbag for your birthday that would match the paintwork.
x2
Hey bunta how do you find your npc clutch? is it the 1000hp one?
went into the panel shop this arvo.
He can fix my front bar :blush: Yay.
He reckons due to the problems matching metallic paint, and the small amount of damage on the guard, it will be better to repair the old guard. That way he can blend the paint so there is no difference at the edges where it meets other panels.
So, bit of a waste of time rolling that guard, but now I have a spare rolled guard I guess...
Anyway, it should all be done next week sometime :D
Got my headlight back too, its come out really well:
x2
its a bit of a bitch, but hey if you dont stall at least once a trip its a girl clutch. Its no worse than say an os giken dampered twin and much better thaqn the old nismo tripple!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
