That's no way to talk about your wife to be
Look at this RAVBAT! Go Son!
Quoted just so I can look at it again :)
Do them in order from left to right 2, 3, 1, 4. Are we playing that game?
Thankyou Colin, I appreciate you saying that about me.
You want to do ravi ? :down:
Who doesn't :)
I didn't even see totally saw Ravi in the pick! Sorry Ravbat. In that case 2, 4, 1, 3, 5... :ninja:
Corrected, and thankyou for even putting me above 5 HAHAHAHAHA.
She really is smokin hot, she just wasn't in the mood for photos at the time.
He is a bit of alright :blink:
Ain't too bad yourself mate :P
Edited by mosquitocoils
see i dont kno - i think the girl on ravis right looks the hottest
Me too without a doubt
+1 on that
I'd go the one on Ravi's left (Right of Ravi in the pic)
marto a simple "+1" or "tristan lets double team her" would have been fine
what's going on with the hair Ravi?
There's Something About Mary moment?
Dude, in that position at that time, wtf do you think!
+1
our right, ravi's left. long brown hair. that chick = win. all the others can be thrown back.
^^^^^^ This man knows where it's at. :)
I still don't know if you guys are talking about the same chick or the 'other' left. If its the same chick, you all need to go back to school. If its the 'other' chick, you all have poor taste :D
according to the chart. I'm Marty McFly ;)
Wheres this chart?
P.S. Morning mangs
blah blah blah
I know how to settle on a winner.
Who's the guy in the photo? There's your winner right there :)
P.S. I just had a mate ask me 'does commonwealth net banking let you transfer money to other banks?'
My response:
You're a f**king tard.
Wheres this chart?
P.S. Morning mangs
Too early in the morning to be thinking this hard.
Here is the flow chart.
Morning peoples
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
