That's no way to talk about your wife to be
Look at this RAVBAT! Go Son!
Quoted just so I can look at it again :)
Do them in order from left to right 2, 3, 1, 4. Are we playing that game?
Thankyou Colin, I appreciate you saying that about me.
You want to do ravi ? :down:
Who doesn't :)
I didn't even see totally saw Ravi in the pick! Sorry Ravbat. In that case 2, 4, 1, 3, 5... :ninja:
Corrected, and thankyou for even putting me above 5 HAHAHAHAHA.
She really is smokin hot, she just wasn't in the mood for photos at the time.
He is a bit of alright :blink:
Ain't too bad yourself mate :P
Edited by mosquitocoils
see i dont kno - i think the girl on ravis right looks the hottest
Me too without a doubt
+1 on that
I'd go the one on Ravi's left (Right of Ravi in the pic)
marto a simple "+1" or "tristan lets double team her" would have been fine
what's going on with the hair Ravi?
There's Something About Mary moment?
Dude, in that position at that time, wtf do you think!
+1
our right, ravi's left. long brown hair. that chick = win. all the others can be thrown back.
^^^^^^ This man knows where it's at. :)
I still don't know if you guys are talking about the same chick or the 'other' left. If its the same chick, you all need to go back to school. If its the 'other' chick, you all have poor taste :D
according to the chart. I'm Marty McFly ;)
Wheres this chart?
P.S. Morning mangs
blah blah blah
I know how to settle on a winner.
Who's the guy in the photo? There's your winner right there :)
P.S. I just had a mate ask me 'does commonwealth net banking let you transfer money to other banks?'
My response:
You're a f**king tard.
Wheres this chart?
P.S. Morning mangs
Too early in the morning to be thinking this hard.
Here is the flow chart.
Morning peoples
