Yes it was :thumbsup: They flew right over the top of the work carpark
I'm still astounded they had 4 F-111s actually flying!!!!!
where is your work?
I captured them in film, and a russian spy plane circled in red! :cool:
and on the fourth day. God said "Needs more low". And John said unto God...
"Niggah please! You pay for it!"
And God said unto John "You have not yet discovered it, but your suspension can drop up to another 25mm. Get the Pintara Twins to help you, and you can have the low. You need to buy nothing else except drinks for the boys"
Without knowning what that bypass hole actually does, yeah it looks like it will work
It goes up over the top of the valve seal, probably just to allow some air to always get through even when the throtle is open
Totally saw the new air force jets today...it was ummm..awesome?
I missed it :thumbsup:
where is your work?
I captured them in film, and a russian spy plane circled in red! :thumbsup:
Northgate/Virginia
I believe that russian spyplane is they mighty hawk.
This weekend is reserved for working on my pintara
I missed it :cool:
Sucks to be you
Edited by Smity42
Correct, people block it for some reason, i have no idea what it is meant to do either way, a mate blocked mine on the R33, it made no difference either way
John give me a call on sunday, i'll lower it. Did you swap the rims front to rear? needs pics of it now?
I officially hate work, it is gayer than gaids, i'll be stuck here until 8pm i think
Sounds good to me! Rims are swapped - pics to come once I finish cleaning the house, looks mad now. Need some epic guard rollage though as now I have scrubbage issues on hard corners. We'll have to enlist the services of your friend who accepts beer as payment :thumbsup:
working till 8pm on a friday is certainly of teh gaids :cool:
@Dan, can you paint tomorrow morning? Early as possible?
Also, do you have any epic blue paint left you could do the ends of my strut brace with? (This doesn't need to be tomorrow).
I will try man, im stuffed from work not sure what time i will surface tomorrow.
told work to stick the job, i ain't working 9 hours tonight
Thanks guys :thumbsup:
I'm happy as with it :cool:
oh and the tyres are ZETUM. Apparently the same as R37 Khumos, just with a different name printed in the rubber. They grip well, and they're not noisy. The test now is longevity.
Dan - what's a good time on Sunday?
damn now them pics are making me wish i kept them now lol lookin good
john lets cut your springs ;)
just saying...
itd go from awesome to f**king epicly awesome with 4 swift cuts with my angle grinder
I can get another 25mm out of my coil overs before we have to do that :)
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
