Yes it was :thumbsup: They flew right over the top of the work carpark
I'm still astounded they had 4 F-111s actually flying!!!!!
where is your work?
I captured them in film, and a russian spy plane circled in red! :cool:
and on the fourth day. God said "Needs more low". And John said unto God...
"Niggah please! You pay for it!"
And God said unto John "You have not yet discovered it, but your suspension can drop up to another 25mm. Get the Pintara Twins to help you, and you can have the low. You need to buy nothing else except drinks for the boys"
Without knowning what that bypass hole actually does, yeah it looks like it will work
It goes up over the top of the valve seal, probably just to allow some air to always get through even when the throtle is open
Totally saw the new air force jets today...it was ummm..awesome?
I missed it :thumbsup:
where is your work?
I captured them in film, and a russian spy plane circled in red! :thumbsup:
Northgate/Virginia
I believe that russian spyplane is they mighty hawk.
This weekend is reserved for working on my pintara
I missed it :cool:
Sucks to be you
Edited by Smity42
Correct, people block it for some reason, i have no idea what it is meant to do either way, a mate blocked mine on the R33, it made no difference either way
John give me a call on sunday, i'll lower it. Did you swap the rims front to rear? needs pics of it now?
I officially hate work, it is gayer than gaids, i'll be stuck here until 8pm i think
Sounds good to me! Rims are swapped - pics to come once I finish cleaning the house, looks mad now. Need some epic guard rollage though as now I have scrubbage issues on hard corners. We'll have to enlist the services of your friend who accepts beer as payment :thumbsup:
working till 8pm on a friday is certainly of teh gaids :cool:
@Dan, can you paint tomorrow morning? Early as possible?
Also, do you have any epic blue paint left you could do the ends of my strut brace with? (This doesn't need to be tomorrow).
I will try man, im stuffed from work not sure what time i will surface tomorrow.
told work to stick the job, i ain't working 9 hours tonight
Thanks guys :thumbsup:
I'm happy as with it :cool:
oh and the tyres are ZETUM. Apparently the same as R37 Khumos, just with a different name printed in the rubber. They grip well, and they're not noisy. The test now is longevity.
Dan - what's a good time on Sunday?
damn now them pics are making me wish i kept them now lol lookin good
john lets cut your springs ;)
just saying...
itd go from awesome to f**king epicly awesome with 4 swift cuts with my angle grinder
I can get another 25mm out of my coil overs before we have to do that :)
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
