there is an issue with going "moar low"
scrub, i would love to take another 15mm out of this baby and get it sitting mint, but normal road driving will kill the sidewalls of the tyres, gaurds need to be rolled, then it can be taken down some moar!
It does sit more level now, A/C was an easy fix, one dud relay and its all good again, start with the basic things when diagnoising faults, then assume the worst. Good to see its nice and cold now, would explain why you were having issues, that relay's contacts are probably fried, i'll pull it apart tomorrow at work when im bored and see.
blahblahblah
busy watching the race :laugh:
What race ? :unsure:
I just skulled a can of rockstar!
Solo man style ?
Thanks heaps Dan! Awesome work :D
Looking good mang.
still needs moar low
That's what she said.
How big are those moths in the IPL ?
+1
Don't worry. As soon as it was off the jack and back on the ground we both thought that. We just need to get Dave to roll the guards first, then we'll drop it some more. There's another 10mm in the front coil overs yet, and another 20ish in the rear.
For now though, I think it looks good.
Car looks better John. Get them guards rolled n she'll be looking sweet. I tried to get some pics of the SR last night but it was too dark. I'll take some when I'm home on the weekend.
Just got this email, not sure if you guys have seen it so I'll throw it up here.
Hi Everyone
If you do not already know and/or have not already done so......This is
for Australian phone numbers
REMEMBER: Mobile Phone Numbers Go Public
this month.
REMINDER all mobile phone numbers are being released to telemarketing
companies and you will start to receive sale calls..
YOU WILL BE CHARGED FOR THESE CALLS
Below is a link where you can enter your phone numbers online to put an
end to telemarketing calls.
Don't just delete those calls otherwise you will find that you have been
signed up for all sorts of extra services that you didn't want or know
about. Like special chimes, music etc..
https://www.donotcall.gov.au/
PASS THIS ON TO AS MANY PEOPLE AS YOU CAN...
Hi Everyone
this month.
http://www.acma.gov.au/WEB/STANDARD/pc=PC_311873
copy pasta
PICS!
Repaired guard on, winRar!
Front end on:
+Bonnet:
Fail:
Fail:
Matt Black Fail:
Vent Fitting Fail:
He also didn clean up the top of the bumber very well. To be fair, this all existed BEFORE hitting the wall, but I would have thought he would clean it up before painting...
And I have NFI what is going on her with this white line:
In for fun and good times this arvo...
^^^ mmm i must get mine done sometime this week
however i think i should probs replace my f**ked tie rod end first to make it worthwhile
lol. Email sounded suss as fuck to start with. How do people keep falling for these things?
'sif you could get charged for an incoming sales call. You can only get charged for incoming servies if you've registered for them.
I wonder how much mobile spam Colin is gonna get now? :D
john car looks good - but as said needs low hahah
what width are the wheels?
It'll get there. Just need to roll guards, and sort out exhaust height :)
@John: Just got my car back from wheel alignment :D Feels good... it's been too long
lol, addict :P
I get mine does this week sometime.
+1 I'm changing mine today or tomorrow. We should have a tie rod end changing party :D
Edited by Isola
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
