Where was my invite you fat shit
EVERY f**king time, I post it on here, and EVERY f**kING time you abuse me for not inviting you :cool:
whats your number then..... ;)
+1
You know what?
It's been far too long since anyone mentioned Serbia.
F*cking serbs
Nearly lost my licence tonight. Now have 1 point left, speeding down an on ramp 129 in a 100 zone.
Lucky bastard in his evo 10 pulled me up cause he heard my bov initially. Checked the engine bay over for about 15 mins, he knew his shit. Saw it was plumb back but warned me that he could still hear it coming out my pod but since there's not an actual venting bov he wasn't gonna bother. Checked the rest over, made sure all my lines were good and tight, no splits etc... so luckily no defects = me keeping my licence.
So yeah, 1 point left. FML.
Edited by mosquitocoils
I thought you said you learned your lesson from the last time. I recall seeing on facebook that you'd never be speeding again? :cool:
on a side note, if we were in serbia, my house would be burning....
BAHAHAHAHA
2 birds with one stone:
farkin lawl
+1
sorry Martin, had to steal your picture to state a point:
http://www.skylinesaustralia.com/forums/Sa...34-t314103.html
I approve :down:
Don't be like that babe, you know I never read them much
Just remember that when I take you to dinner, I expect you to put out
3358 wub
I want the 1900 number...
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
