Tristan you should talk to Dan at ERD, he is pretty sick at over the phone diagnostics, just dont take too much of his time cause i want him to finish my engine :)
you help me think of a solution to my problem and ill slide up and down your disco stick :)
You always promise these things, but you never deliver.
I'm still waiting for my BJs from helping with the ESSS ARRRRRRRRRRRRRRRR
someone just replied saying AFR should be checked out and therefore needs dyno time
he also said 1 bar is too high on stock injectors/afm
ugh GAY
@andy - does dan from erd have the SR love? if so ill give him a call on my lunch break
He has some experience with SR's, he is the RB guru but very good with SR's too
but if he suspects it is sensor or elec problems he will likely send you to EFI, which will make you cry, because they have an ocilliscope and he doesnt
ugh GAY
thats probably right, with the bigger turbo running that boost I imagine you are running very close to the limits of the stock injectors, and ya the sr afm is a pos
bigger injectors, RB afm and retune and im betting the problem goes away
ocilliscope?? huh?
overlays the outputs of sensors and injector pulses in real time so you can see how all of those things are realting to each other, its awesome
Wikipedia confirms awesomeness.
On a side note I love how google is now a verb.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
