Cool! We can make it a mixed team, I dont propose we make an official team, just a bunch of people turn up of a sunday arvo in a park somwhere and play, at school we would do this all the time we would play league rules and use peoples shoes to mark the field lol
We could play red rover too
Preliminary Rollcage Ideas (courtesy of a picture off the internet and MSPAINT)
Green bits will be included if they are affordable and allowed under CAMS (nothing about them in sched. J of the cams manual though)
Purple bit will only be included if its cheap and the cage builder tells me its worthwhile.
Not sure which way to go with side intrusion yet. If double, apparently the old school X is not strong at the join, it needs to be gussetted or use two bent pipes welded together instead.
If single, I think I prefer it running right back to the harness bar as it doesn't create a bend point halfway up the main loop then...
What about the ladder style side instrusions? And the purple bit is the other bar to make the roof cross/X right? Would of thought that would be pretty standard for a cage builder to deal with ie not that expensive? Stuff penetrating the firewall is generally more expensive and difficult from what I've seen/read about on the internet.
I would prefer the two bent bars for the side intrusion but it's not like it's door to door racing so you're not likely to have anyone come crashing through your drivers door.
Squares are bad. Triangles :ninja:
Yeah, but I think the second part of the "X" is redundant here. Leaving it out will save weight and probably cost. Unless the engineer tells me its important its gone.
Yeah, but it also gives the most benefits for chassis rigidity. If its allowed by cams and not stupidly expensive, I'd like to include it.
Yeah I havend decided yet... the two bent bars would be best but the single bar would be lighter and probably enough. Unless I decide to use it for rallying and then I'd want the double bars.
I'm also tossing up wether to put a harness bar on the main loop as well so I don't have to run them right to the back...
wow there is a blast from the past
that got banned at out primary school due to injuries lol
Or force em back with the footy
great days... great days
Triangles obv > squares agree was just throwing it up as another option.
Most of the cages I've seen either have an X or a V in the roof. If engineers reckon it isn't needed I'd leave it out but I'd always want that extra protection if a roll over happens
Definitely better for rigidity but I only ever see it on the more serious cars which makes me think it will probably be prohibitively expensive.
Have a look at how Risking on here does his cages. He has the harness bar in the main hoop aswell I'd rock it like that if you can
Yeah found this thread, it's given me a few ideas for changes.
I might go with the V roof, it looks pretty strong (triangles) and not much more weight than the single bar
so who's coming tonight?
Martin & Dan will be westward bound for project alfa and thus be late.
I don't want to be just sitting there with my dick in my hand for 2 hours... so who else is coming?
league rules wins = epic grubbers and 5th tackle plays
Yeah football with out kicking is a bit shit, The only real problem you get is knock ons, leads to some interesting convos, so perhaps league rules with one touch rule, that being if the ball hits the ground its a turn over.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
