and for the rest of the thread:
Happy birthday Josh and Tristan
I'd probably go along to wherever you're playing football to watch/socialise/eat food while you all run around.
Good luck with the roadworthy ravi. Bring it to BR so we can check it out. And bring some bitches for Martin. There's only so long he can watch through the window before they get a restraining order.
get your tractor fixed thristian?
Yeah I reckon somewhere northside but closish to the center of town is your best bet for footy
yeh mate got it all sorted - gasket fitted, front pipe replaced :) - the jap front pipe fits sooo much better than the cheapo china one that was in it
Martin these are the wheels I have at home. They came off my 33 when I bought it. No idea on offsets but I'm pretty sure they are 8.5 wide. Are these the same ones you were talking about last night?
edit: mine are 17s aswell. the ones in the pic are 16s
zomg sell/give me a pair?
Happy birthday Tristo...
The laser's having a roady done today so fingers crossed hahaha!
thanks sexy
excited for car trips next week?
so, when we're playing with pipes :D
pipe work is done - i think i want twin pipes, im 90mm under the car, but the cannon puts it at 70mm - twin pipes would fix that and look uber lolzz
Yeah happy birthday Tristan!
And happy birthday for yesterday for Nismoh!
<3 :ermm:
Yeah forgot about that. Happy birthday Josh n Tristan ;)
i wnat to touch you
Well it phailed miserably. Got a list to look at, usual crap like brakes, seals (oil leaks etc), one tyre blah blah blah... most of it I should be able to do myself, but rear main seal? Really??? Never taken a box off before, but I'm willing to try... opinions anyone?
Also front and rear link pins? Don't even know what they are lol
pipe work is done
i wnat to touch you
gearbox rear main seal? f**k man - front wheel drive boxes are a joke
replace the tyres and brake pads, and degreze the engine bay then call me :)
no idea wtf link pins are :ermm:
no idea wtf link pins are :)
I had link pin suspension on the front of my '73 bug. The '67 had link pin front and rear.
That's probably what they're talking about.
this is what the front of my bugs used to have:
Does the TRD Laser have something similar?
Edited by Isola
I wish!! f**k I want a dune buggy now!!
So I found out it was the link pin bushes (ends of the swaybars) and a kit for the front or rear is like $20... so I have one and will attempt it this weekend, should be a piece of piss.
Got the brakes too and all the other little things like the clutch rubber thing, nice solid battery clamp wah wah wah.
And yeah I'm gonna degrease the underside around the rear main seal, but the front crank seal + belts, idler blah blah are all gonna get swapped anew when I get some spare cash in a week or two, and that should see me pass roadworthy as the front crank seal + cam seal were the worst offenders for oil leaks. No so keen on doing it myself.
you REALLY want to run spacers on a track car? :)
Yes, hub centric bolt ons a perfectly safe. In fact, CAMS rules state you can have 1 spacer behind each wheel.
Just queensland transport that are gay
well sweet as then :) let's go put some cars up on bricks :)
dude hit the engine with degreaser and the next day take it back, or take it to a different place :)
Yeah I could do that, but at the same time this car will keep going forever after a bit of TLC, so I might as well do it right the first time.
That's so unlike me, I'm always about the quick fix, just get it good enough.... what the f**k's going on!!
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
