Im listening
I hate it when you put words in my mouth Nismoh
I see youve played RAPE as well.
It's not rape it's suprise sex :thumbsup:
Shh, Thristan will get upset.
Is everyone still doing "winter" ice cream?
Thristan will understand :thumbsup:
We're there every week you should come and play cars with us Josh
Morning Mangs
Morning
Also a good use of duct tape
The jailbait is there regardless of temperature...
I wanted to play something else with Josh...
I'll come this week if Thristan is still driving me
Sick
Can I wear a scarf if I come?
I'd be disappointed if you didn't accessorise Josh
cheaper option: Duct tape a hose to the trumpet(s)
I had thought about it TBH... will it recirculate well enough to not blow shit up though? or well enough to not cause random stalls making me look like an L or P plater?
Definitely.
If your hose is big enough (that's what she said)
yeah, but does it vent as much through the 'trumpet' as it would through a recirc hose/pipe? Or does it only vent a portion of what a recirc BOV would vent back into the pipe work, and send the rest back to the turbo? I don't really know how atmo valves work to be honest...
afaik, they work exactly the same, just an atmo one dumps the air to atmosphere (usually, but not always, via a trumpet of some sort) while a recirc one runs a hose to dump the air back into the intake.
Guess there's only one way to find out if it'll work then. :happy:
Bingo. We recently had to turn Annas atmo bov to plumbed back and all it required was the right size hydraulic hose (bendy and built to take pressure) and some hose clamps. We tried other hose but it kept getting holes blown in it
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
    • Well, I was using ECUTalk software if that helps? Not sure if that only can see engine codes? Is there any other software I could give a try? Or any way I can get a blink code?
    • I never touched it, it should have. I'll try to give it an adjust. With IACV plugged in, it idles at around 1120RPM on average. Max 1200 RPM, Minimum 1025RPM before it starts dropping right before stalling. Took the data from the Nistune logs.
    • Thats what im trying to solve bro  no one with aem tuner experience would advice  much appreciate
