Im listening
I hate it when you put words in my mouth Nismoh
I see youve played RAPE as well.
It's not rape it's suprise sex :thumbsup:
Shh, Thristan will get upset.
Is everyone still doing "winter" ice cream?
Thristan will understand :thumbsup:
We're there every week you should come and play cars with us Josh
Morning Mangs
Morning
Also a good use of duct tape
The jailbait is there regardless of temperature...
I wanted to play something else with Josh...
I'll come this week if Thristan is still driving me
Sick
Can I wear a scarf if I come?
I'd be disappointed if you didn't accessorise Josh
cheaper option: Duct tape a hose to the trumpet(s)
I had thought about it TBH... will it recirculate well enough to not blow shit up though? or well enough to not cause random stalls making me look like an L or P plater?
Definitely.
If your hose is big enough (that's what she said)
yeah, but does it vent as much through the 'trumpet' as it would through a recirc hose/pipe? Or does it only vent a portion of what a recirc BOV would vent back into the pipe work, and send the rest back to the turbo? I don't really know how atmo valves work to be honest...
afaik, they work exactly the same, just an atmo one dumps the air to atmosphere (usually, but not always, via a trumpet of some sort) while a recirc one runs a hose to dump the air back into the intake.
Guess there's only one way to find out if it'll work then. :happy:
Bingo. We recently had to turn Annas atmo bov to plumbed back and all it required was the right size hydraulic hose (bendy and built to take pressure) and some hose clamps. We tried other hose but it kept getting holes blown in it
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
