nissan factory manuals sh*t all over these alfa ones
Fair enough. I think dad has an old haynes manual for Escorts around somewhere. Love haynes manuals.
+1
+1 good call Ravi.
not so much for crash but for chassis stiffness. The extra diagonal in them is probably a waste but I don't like squares :)
What about just an X rather than the square with a diagonal. I'd say it would provide similar stiffness with less weight.
oh, and will seam weld from the a pillars to all the front suspension mount points. Theres just no practical way to get enough cage bars through there :D
Sounds good. Whats the goal for completion? Is it going to be fairly drawn out ie 2012 sometime or are you going to hammer it through and be racing in 2011?
oh hai!
whats happening guysss?
ps i just drove down stafford road - phantom motors no longer exists?
Hai sexy legs.
nm is happening mang just working. You get your exam timetable yet? 8,10,17,18 and 22nd of June for me. Spread out a bit which is good but 5 exams fml.
Phantom have relocated I think.
Hai sexy legs.
oh true shit hey
i got 8,10,15,22 - so you and me beers on the 22nd?
oh hai!
Whats there now?
Are you happy with the tune you got from STZ mang? They are a haltech premium rep or something... (gonna run a PS2000 on the alfa)
X's are just as bad as squares. Think of a pair of scissors... although an X with the 2 ends (no sides) might be OK, ie:
rear brace->|X|<-harness bar
worth considering...
Whatever time/money/parts availability permits. Seems to be no luck getting an engine at this stage... :)
i vote racing in 2011
Would be nice :D
oh true shit hey
In.
Tis what I was thinking I just suck at putting it into text lol.
Fair enough.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
