oh, and will seam weld from the a pillars to all the front suspension mount points. Theres just no practical way to get enough cage bars through there :3some:
Actually it looks like it may be possibly, by going inside the front guards (which are welded on :)). I might look at how to get those suckers off...
Whats there now?
Are you happy with the tune you got from STZ mang? They are a haltech premium rep or something... (gonna run a PS2000 on the alfa)
there is nothing there - its 100% bare.. hence why i asked
f**k moving all those cars - would have taken ages, would have been a fun night however lol
mate STZ were amazing, car runs so sexy - marty and mic said if there are any dramas just pop in and they'll have a look
defs recommend them bro!
their s13 runs a 60.2 on QR Sprint track - go figure, that thing has the haltech in it (and an SR :3some:)
cant remember what turbo/power figure, but its definitely a very "tame" set up (not like high-octane racing for example)
give them a buzz fo-sho
I say dan buys it and sets up a workshop there :3some:
their s13 runs a 60.2 on QR Sprint track - go figure, that thing has the haltech in it (and an SR :))
Cool as, they are about 2 minutes from my work :down:
...Will be a while till I need a tuner though ;), just doing my research...
Cool as, they are about 2 minutes from my work ;)
...Will be a while till I need a tuner though :) , just doing my research...
dude lets buy it - hoists win!
but yes STZ ftw! should go down and chat to them, i was there for ages just chilling - great guys
I say we all chip in and make it an Apocalypse fortress :3some:
Keen for apocalypse fortress/ somewhere with a hoist. but John needs a job first :)
Martin i can chase down the original workshop manuals for the GTV.
Phantom has relocated over near moss street from memory, i wanted to take the RX7........
If someone wants to front the cash i'll setup a workshop there and mini skid track.
Also, concrete carparks in the wet are too easy
I have them on that disc. They are sh*thouse :thumbsup:
I did find the bit for adjusting suspension though. Height, Camber, Castor, Toe all adjustable on the front from factory :(. Looks like nothing adjustable on the rear :)
Build your own damn fort then.
Fine maybe I will...
Workshop+skid track = win.
Morning Mangs
Epic fog is epic :thumbsup:
Morning mang no fog here but it's pretty quiet on the way to work these days.
Morning to you fine gents
The fog's actually gotten worse since 6am...... go figure, usually it works the other way
Night all.
Is it just me or are those roll over ads at the top a pain in the rectal area? :):thumbsup:
I have them on that disc. They are sh*thouse :(
I did find the bit for adjusting suspension though. Height, Camber, Castor, Toe all adjustable on the front from factory ;) . Looks like nothing adjustable on the rear :D
That's awesome. How much adjustability do you have though?
Could be that deadly fog that turns people inside out. I here it has been getting around again.
Night all.
So true. But they have to make money somehow.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
