What daily?
Slip on spacers give you aids.
Coronas are for phags.
What new wheels you get mang?
Assignments suck balls.
TRD mazda
+1
+1
+1
+1
- mazda 323, grandma/showroom spec, im in love <3
- if a 2mm allows hektik camber im keen!
- coronas are tasty, i dont think u appreciate that they were delivered to me by gf = awesome
- just picked up another pair of zenkais, so that makes 8 - so 6 skidders and 2 steers :P:) (matching wheels is hot, as apposed to good fronts and stockos on rear)
- yes this assignment is a joke
Up at the PA.
Thanks guys
all the best bro
@John, Dan, Geoff, and anyone else coming:
Are we still going to hit up saturday even if Jason can't make it? If yes, what time are you mangs going to rock up?
And whats the list of stuff to do again? I may not be able to turn any wrenches (elbow is f*cked) but I can still solder, offer advice/abuse, etc...
If i can make it i will be there in the morning but have to start work at 3pm so it wont be a full day
Well I'd still like to. We can always do Jason's car another time. Time is up to you and Dan. He said early.
List for stuff to do for my car:
Try and get 4WD working/bleed/abs check etc
Install MBC and boost gauge
Experiment with the two SSQVs
And hopefully Sir Sexy Dave can at least roll my rear guards to stop me getting defected :P
Lol, TRD is tuning everything these days
All dailies are TRD tuned.
I should get a TRD sticker for the Getz and see if even gets noticed.
Group buy for TRD stickers anyone? Would look good on the SexF, Martin :P
Give her best wishes from the SAU boys.
Keep the spacers 3mm or under
and +1
Churrrrrrr!
Don't stress yourself at the moment bud
KEEN
- just picked up another pair of zenkais, so that makes 8 - so 6 skidders and 2 steers :) :) (matching wheels is hot, as apposed to good fronts and stockos on rear)
all the best bro
- HAHAHAHA what year? Is it the same as Ravi's laser? (Lasers back then were just rebadged 323s)
- Aids
- If I had a gf and she gave me coronas, she'd be sleeping on the couch (or worse) :)
- Nice, did you gay these ones up too (aka matt black)?
- Sucks to be you
Early I can do, just let me know so I can be up, have pants on, etc.
In fact early is probably better, as I have to get up at like 6am sunday for corporate games. Oh, and have to make sexy time at planet on sat night.
Cool, sounds like a lot of work for Dan and a lot of drinking for me. I'll assume Dan is sorting it out with Dave.
Group buy for TRD stickers anyone? Would look good on the SexF, Martin ;)
Keen.
-1. Bolt ons or nothing.
+1. There's always another day to play with cars
finally got my 33 back, so wondering if everyone that usually goes to the baskins meet is going tonight? im keen to meet up n c other skylines tooo :P
I really need some brakes, as Anna wants mine for the sil80, im thinking R33 brembos, but my mate works for a v8 ute racing team and they run alcons....but would need adapting.
hmm not sure what direction to take, this car has been all about enhancing rather than re-engineering so a bolt on fit does appeal, just not sure they will be enough though!
PS, Skins my boss is going to give you a call, im not sure what jobs are on offer atm but he does want to talk to you so i guess thats a start!
Atomicbomberman had some impressive brembo brake calipers with him one night. Ferrari ones or some such. Dan or Martin might remember. He was putting them on his 32GTR and they looked like MORE than enough.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
