Kunce!
Scarnon?
Got my neo turbo today :ninja: looks good rear seal might be shagged though
Mr. Coils. If you give them to me I can get the fitters at work to sand blast them for you
Sick! Any advantage over your S2 R33 turbz though? I always thought they were the same internals, and the S1 R33 were the different (slower spooling) ones
Done deal. How does that bring metal up? You think they'd want any moola for that?
Fire
Oh shush now
Or fire that was my next option :P
Don't encourage him
Oh shush now
Don't encourage him
neo turbo has a larger rear housing
:ninja:
They won't I will :(
Oh shush now
:P
Don't encourage him
:D
Hey andy :)
rust free, but needing treatment. so when you get it back, clean it really well with stuff that'll get finger acid and other nasty things off, then treat it with a good heat resistant paint.
Lol very nice John. This could start an epic tag war. But I'm at work so :P When I get home it's on like donkey kong.
Morning Mangs
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
