Kunce!
Scarnon?
Got my neo turbo today :ninja: looks good rear seal might be shagged though
Mr. Coils. If you give them to me I can get the fitters at work to sand blast them for you
Sick! Any advantage over your S2 R33 turbz though? I always thought they were the same internals, and the S1 R33 were the different (slower spooling) ones
Done deal. How does that bring metal up? You think they'd want any moola for that?
Fire
Oh shush now
Or fire that was my next option :P
Don't encourage him
Oh shush now
Don't encourage him
neo turbo has a larger rear housing
:ninja:
They won't I will :(
Oh shush now
:P
Don't encourage him
:D
Hey andy :)
rust free, but needing treatment. so when you get it back, clean it really well with stuff that'll get finger acid and other nasty things off, then treat it with a good heat resistant paint.
Lol very nice John. This could start an epic tag war. But I'm at work so :P When I get home it's on like donkey kong.
Morning Mangs
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
