Yep I have the manwell for it. I downloaded it from the website. I went to the off setting and it didn't seem to do anything. It was still giving me infinity boost.
F*ck, that's not good :ermm:.
Bring the manwell tonight, saves me having to print it.
Lol @ NASA
Voyager 2: *Gibberish*
NASA dude 1: Hmmm, voyager 2 seems to be broken
NASA dude 2: Have you tried turning it off and on again?
NASA dude 1: Naah, we'd better figure out whats going on first
several days later...
NASA dude 1: Yeah I figured it out, theres a bit-flipped in memory
NASA dude 2: OK, how do we fix that then?
NASA dude 1: Lets try turning it off and on again...
ATTN: Phil, Misohorny, John, Dan
Work out a day that works for everyone to fix Jasons AVCR and do Miso's brakes. Dan will need his brake bleeder. I can't do it this weekend though.
I am easy. Just let me know and i shall be there. Can work it out tonight at baskins. No longer jet lagged, so won't sleep through it. :ermm:
Sounds expensive. So whats doing mangs? I'm typing meeting minutes :D
Trying to clean up scanned alfa wiring diagrams to print. HOPEFULLY they are the right ones :S
Cool, sounds like it will be a good turn out tonight. Thristian, you coming?
Sounds expensive. So whats doing mangs? I'm typing meeting minutes :(
Very expensive. You can only import them.
I am easy. Just let me know and i shall be there. Can work it out tonight at baskins. No longer jet lagged, so won't sleep through it. :P
Anytime is good for me ( if i can afford to drive there :D ) I'm on day shift this week and next and have this weekend and next one off. :ermm:
Anytime is good for me ( if i can afford to drive there ;) ) I'm on day shift this week and next and have this weekend and next one off. :down:
I think tonight we will just bypass the AVCR and pipe the wastegate actuator directly to a boost source. This should put you back to stock boost (stock LOW boost probably) which will get you by (and hopefully fix your fuel economy) untill we can sort it out. Hopefully next weekend will work for everyone.
If it still boosts it's t*ts off, or you still get bad fuel economy, then you have other problems.
I'm not 100% sure how the AVCR can be ruining your fuel economy so much, if anything I would have thought it would make it better as you'd be trying to drive off boost all the time...
Edited by Smity42
+1
o2 sensor? when was that last replaced?
+1
I've only had shitty fuel economy since the avcr. But it is getting worse and worse. How much is a o2 sensor ?
Jason... did you let you car hang out with mine again? I started her up this morning and she was all lumpy and shaking and carrying on, and drives like a bucket of shit :down:
Just letting it cool down now so I can see if I can work out wtf is going on with it ;)
like $100ish i think man
i have a spare good one you could try - if they fit (its an sr one)? idk if they do
was the avcr new? who installed the avcr? i'd give them a bell maybe they f**ked up? (or was it you that fitted it :down:) jks jks
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
    • Thanks guys - I have been overseas for a hectic many weeks , so haven't had time to chase any of these up.  Some of the suggestions are for 4.1 ratio, which I already have, and a 3.5 at Lonsdale, which is also too tall.  Really looking for 3.9 or even a 3.7 LSD, either with M12 bolts. Will look some more.
