Yep I have the manwell for it. I downloaded it from the website. I went to the off setting and it didn't seem to do anything. It was still giving me infinity boost.
F*ck, that's not good :ermm:.
Bring the manwell tonight, saves me having to print it.
Lol @ NASA
Voyager 2: *Gibberish*
NASA dude 1: Hmmm, voyager 2 seems to be broken
NASA dude 2: Have you tried turning it off and on again?
NASA dude 1: Naah, we'd better figure out whats going on first
several days later...
NASA dude 1: Yeah I figured it out, theres a bit-flipped in memory
NASA dude 2: OK, how do we fix that then?
NASA dude 1: Lets try turning it off and on again...
ATTN: Phil, Misohorny, John, Dan
Work out a day that works for everyone to fix Jasons AVCR and do Miso's brakes. Dan will need his brake bleeder. I can't do it this weekend though.
I am easy. Just let me know and i shall be there. Can work it out tonight at baskins. No longer jet lagged, so won't sleep through it. :ermm:
Sounds expensive. So whats doing mangs? I'm typing meeting minutes :D
Trying to clean up scanned alfa wiring diagrams to print. HOPEFULLY they are the right ones :S
Cool, sounds like it will be a good turn out tonight. Thristian, you coming?
Sounds expensive. So whats doing mangs? I'm typing meeting minutes :(
Very expensive. You can only import them.
I am easy. Just let me know and i shall be there. Can work it out tonight at baskins. No longer jet lagged, so won't sleep through it. :P
Anytime is good for me ( if i can afford to drive there :D ) I'm on day shift this week and next and have this weekend and next one off. :ermm:
Anytime is good for me ( if i can afford to drive there ;) ) I'm on day shift this week and next and have this weekend and next one off. :down:
I think tonight we will just bypass the AVCR and pipe the wastegate actuator directly to a boost source. This should put you back to stock boost (stock LOW boost probably) which will get you by (and hopefully fix your fuel economy) untill we can sort it out. Hopefully next weekend will work for everyone.
If it still boosts it's t*ts off, or you still get bad fuel economy, then you have other problems.
I'm not 100% sure how the AVCR can be ruining your fuel economy so much, if anything I would have thought it would make it better as you'd be trying to drive off boost all the time...
Edited by Smity42
+1
o2 sensor? when was that last replaced?
+1
I've only had shitty fuel economy since the avcr. But it is getting worse and worse. How much is a o2 sensor ?
Jason... did you let you car hang out with mine again? I started her up this morning and she was all lumpy and shaking and carrying on, and drives like a bucket of shit :down:
Just letting it cool down now so I can see if I can work out wtf is going on with it ;)
like $100ish i think man
i have a spare good one you could try - if they fit (its an sr one)? idk if they do
was the avcr new? who installed the avcr? i'd give them a bell maybe they f**ked up? (or was it you that fitted it :down:) jks jks
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
