:(:):):D
BOV is wound all the way in and it still stalls.
Joyish moment today, upon inspection have found that power steering reservoir is floating free. Am missing some nuts. Oh joy of joy
so im assuming from the silence here that phil has run out of fuel on the way home? or did martin installing the solenoid correctly fix the issue?
Also, john we did not hear enough bov
pffft run out of fuel... I was just lucky it didn't wreck or explode :) . Bit over one bar ( thats what she said ) see how we go tomorrow
Would you like to borrow one of my stock BOVs? It'll get rid of your flutters like you wanted.
Yeah... pipe didn't work. Did some roadside tuning (read: ripped the cunt off) after dropping off Colin. Needs a tiny bit more tweaking tomorrow. I'll just run it as is, should be fine.
Dan = grace
Dan != Grace. Not in any way :P
i wouldn't leave the house if that was the case.....
lol
yep resetified it when i got home.
That's what she said?
Any rush for these parts Tim ? I won't be able to get them done until tuesday next week :D
No rush Phil, no rush at all.
Werd
Morning mangs scarnon ?
Morning mang.
Counting down for the weekend. Scarnon with you?
gettin` jiggy wit it
Keen for German Club on wed night? (Origin night)
Morning mangs...... how was ye olde ice creamery?
@ Jason......... I'll give you a bit over 1 bar. Also don't be held back by your pipework hahaha go to supercrap and scour through all the radiator hoses til you find something that you can cut, or will bend to suit!
I'll also have those extractors this weekend hopefully so hopefully can get done at the same time as Tims?
Also wouldn't the german club be packed for origin? I'd say any drinking establishment within Brisbane would be... especially with food :P
Dan != Grace. Not in any way :D
lol
Werd
Morning mang.
Thats good then. Should have them all done and dusted on tuesday arvo. Did you want them early or just bring them on thursday ? I've never been to the german club. Are you allowed to mention the war? :D
Keen for the bar. :P
Pffftttt couldn't be arsed. I'll just saves up some monies and get someone to fixafy it for me. I'll have to ask the fitter if he can do it at the same time. Might cost you some beers :)
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
