:(:):):D
BOV is wound all the way in and it still stalls.
Joyish moment today, upon inspection have found that power steering reservoir is floating free. Am missing some nuts. Oh joy of joy
so im assuming from the silence here that phil has run out of fuel on the way home? or did martin installing the solenoid correctly fix the issue?
Also, john we did not hear enough bov
pffft run out of fuel... I was just lucky it didn't wreck or explode :) . Bit over one bar ( thats what she said ) see how we go tomorrow
Would you like to borrow one of my stock BOVs? It'll get rid of your flutters like you wanted.
Yeah... pipe didn't work. Did some roadside tuning (read: ripped the cunt off) after dropping off Colin. Needs a tiny bit more tweaking tomorrow. I'll just run it as is, should be fine.
Dan = grace
Dan != Grace. Not in any way :P
i wouldn't leave the house if that was the case.....
lol
yep resetified it when i got home.
That's what she said?
Any rush for these parts Tim ? I won't be able to get them done until tuesday next week :D
No rush Phil, no rush at all.
Werd
Morning mangs scarnon ?
Morning mang.
Counting down for the weekend. Scarnon with you?
gettin` jiggy wit it
Keen for German Club on wed night? (Origin night)
Morning mangs...... how was ye olde ice creamery?
@ Jason......... I'll give you a bit over 1 bar. Also don't be held back by your pipework hahaha go to supercrap and scour through all the radiator hoses til you find something that you can cut, or will bend to suit!
I'll also have those extractors this weekend hopefully so hopefully can get done at the same time as Tims?
Also wouldn't the german club be packed for origin? I'd say any drinking establishment within Brisbane would be... especially with food :P
Dan != Grace. Not in any way :D
lol
Werd
Morning mang.
Thats good then. Should have them all done and dusted on tuesday arvo. Did you want them early or just bring them on thursday ? I've never been to the german club. Are you allowed to mention the war? :D
Keen for the bar. :P
Pffftttt couldn't be arsed. I'll just saves up some monies and get someone to fixafy it for me. I'll have to ask the fitter if he can do it at the same time. Might cost you some beers :)
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
