You are clearly referring to a trial, where Colin in an exhibit in a rape case.
You sir, are correct sir.
:wub: I am one sexy motherf**king Ranga :bunny:
Also guys... What does a f**ked engine mount/s sound like? My mates mx6 is making noise when accelerating or turning right & accelerating at the sane time, but doesn't make the squeaking/rubbing noise when travelling out of gear, and it doesn't appear to be suspension or motor related
more like - what does it FEEL like. Hektik shudders that you can feel through the firewall when the car is idling is usually a giveaway. Similar to power steering shudders, but more hardcore.
more info on what it sounds like?
Mm yeh no shudders at all... Sounds kinda like a belt or low pitched rub or scrape. Not very loud but notoceable. His battery died 2 months ago so I just suggested alternator area, maybe the pulleys loose or similar? Or a bearing on it?
timing belt cover isn't rubbing against the belt is it?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
