The only problem with downloading music is the time it takes to rename everything from the stupid assfucked format that people have to save shit in before they upload it.
Why can't they just do
Track Number>Track Name ?
It's always something like Artist>Album>Track Number>Track Name>Year>Sample Rate>and 14 other bloody things. I know what artist it is because it's in THAT FOLDER! I know what album is it because it's in THAT SUB FOLDER! Dickheads.
Evening gents
at john : I asked about the football as I was hoping you'd have a bluetooth head set on and spin around to your computer and go tak tak tak tak and then get back to me re-afl. all in a 24 type feel.
But it didn't happen :)
Evening gents
But it didn't happen :wacko:
I don't use bluetooth headsets. I'm not in my 40s :) Even Jack Bauer has a plugged into his phone ear piece.
My phone was actually plugged in charging in the other room sorry dude. Plus I didn't know you wanted me to look it up. I just read AFL and felt dirty and that was about it.
Dude... the dam busters... what time is it happening? Have to be home before 630 on Sat because Alyssa is having her birthday party that night
it's showing you logged in
That's weird. I wasn't. I am now though just in case some freak of nature happens and it works.
How many pages did we get through last night ?
I'll be too lazy then too. you check. I'm going to cook sausages - back shortly.
you and your midnight dining. here i am with dodgy cheezels.. blergh :)
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
