as requested:
Desk is shared between 2 of us, red line indicates approximate position 'my' desk ends
that fkn blows! good thing you dont have any work to put on it :D
damn, were are you to put you footlong sub on that?
man my workbench you could have a party on. Actually come to think about it you could, 2.5mm thick stainless steel is hella strong my hammer can't dint it
Works in service..
11pm - 6am kind of job
I wouldn't need a desk for that :)
Miso, my qualification is in Computer Systems Engineering (Read: Software Engineering). My current role is hard to describe, basically I do semi-HK IT stuff (ie not "Have you tried turning it off and on again" ) :D
Bring it to the German club
German Club when?
See you later Jason, have fun in Auschwitz
It's not such a bad place :)
Nice desk by the way :D You should put up some police line do not cross tape where the red line is :3some:
    • bumping this post as im still having dramas, my fuel pick up is sitting on the bottom of the tank, my pump gets a constant 13 volts through a relay, my fuel pressure holds consistently without fluttering or dropping, yet as soon as im near half a tank of fuel my car starts fuel starving and leaning out, it cant be due to g force as it never pulls hard enough before it starts breaking up, any help would be much appreciated
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
