I declare F-Duct drinking game a success! I am nicely munted, and that was only qualy :)
I am thinking of introducitng a bonus round of some sort for vettel being a tool... details still to be worked out :D
my everything hurts.
Was having a jam session at a friends girlfriends house, in the room we were in theres a pillar that runs across the ceiling and being a tall bastard and all, I have multiplied my hangover by walking into it.
I am thinking of introducitng a bonus round of some sort for vettel being a tool... details still to be worked out :blink:
Drinking game.
Sign me up :(
What job do you have which requires work on a sunday?
I make sure you have water coming out of your tap in a nice controlled way.
Not like that.
Like this.
I made some light progress on my project car, i cleaned the garage, then realised i can't actually do anything i wanted to do this weekend cause i need to get the guards lipped before i can put the coilovers back in. And that the coilovers need new pillowballs and heavier springs. Hopefully will sort that for next weekend thought.
This arvo i started sanding back panels and getting them ready for the primer coat.
Sounds productive. :blush:
Whats a pillowball :happy: ?
sure are, they are my upper shock mounts, also known as Spherical Bearings. I'd really like to get brand new ones but i don't know where to get them from.
In other news, only a couple days until i get awesome pints'o beer and lamb shanks!
Whats a pillowball :blush: ?
I've got two in my pants, if you'd like a demonstration?
So much win! Gonna go for the pork knuckle!
Anyone know/recommend a good detailer on the northside? Mate wants his car done inside and outside before he sells it
Always you know that :blush:
Ask Sabbai.
