multistud
colin buy buy buy! go 9s but :)
bought gone 8s front 9s rear though. 205/40/17s on the front and 215/40/17 on the rears
What's this for? Your 31? Cause you must be more camp then a row of tents, if you are going to run them over what you have on your 32.
haha yeah its for the 31. 1 of the works cost the same as the set of these ones :)
colin im epic impressed :D
and you'll be impressed by my epic reading :P
and ill be impressed by your epic football tonight - provided you dont play like the english defenders :P
