did you check out the SUN newspaper the next day?
cronic lolz to be had
articles ranged from
WHICH PLAYERS NO LONG DESERVE AN ENGLISH JERSEY (in which they named all players except gerrad and rooney)
to
10 MISTAKES THAT CAPELLO MADE WHICH LEAD TO DEFEAT
to
ITS TIME YOU GO CAPELLO
i was rofling all day at work reading them
to
to
I refuse to read the Sun after they blamed Liverpool supporters for the Hillsborough disaster. The editor is an utter twat. I wouldn't want to be the english players going home they will be getting crucified. Its ridiculous.
oh yeeh man - its a bullshit paper - they just flame anyone and everyone
english footballers are getting falcon punched something cronic
twat... now there's a proper english word!
Good form on the rims colin should be epic
Update on project 31, not much time tonight cause i got home late, however. Filler panel and grill have been sanded back and primed. Front guard has been removed and the lip folded in. Won't get anything done on it tomorrow cause i'll be drinking.
Also i don't think i'll be at baskins' on thursday night. Might have myself a function to attend
I can only take 2.
I got colon and a mate. So i'd be full.
Bus to the gabba and then walk!\
huh?
Edited by Tony350
officially requesting transport for 3 people between city and german club tomorrow night. Or further northside if anyones coming from that way.
Who can help? :(
train to south bank bus or walk to gabba, Easy!
Sorry dudes, looks like I'm out for german. One of my best mates is leaving for London tomorrow night (which I've known forever) and I'm sorting everything out with his laser that I bought tomorrow night after work, plus also hanging with him and his misses and other friends one last time :blush:
If for some reason that changes, I'll still come meet you all for some sick knuckle action :blush:
Tony:
The cars I was talking about that all have the same profile. There are probably others that I haven't seen yet too. Car manufactures just aren't bothering to design anymore.
Edited by Isola
Morning mangs, scarnon
Yes yes, but this is plan B. It is much easier and quicker if someone is going past and can give a lift. We already have ~1hr public transport trip to get into the city
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
