@andy Awesome news! I need new pants
@thrustion, won't be able to helicoil up that far, you'll need a proper adapter, the same as your old one probably. I don't know where you would get one though :D. Go back to the dodgy bastard that sold you the dildo knob (I'm assuming you bought it from my best mate) and tell him to find you a new adapter. Don't pay him though!
Helicoils are for stripped threads, they won't do an M10-M12 spec change. You'll need an adapter, don't know if bunnings will have one or not.
sorry mang i misunderstood!
guess its no dildo tmr then :D
so tyre run trip is canx?
Nope. Tyre run trip is in process of orgamisation.
Scouts can do a BBQ for the day but need to know what people wants to eat i.e. burgers, or snag in bread for costing per head.
The tyre shop can do a good discount but need to know what sizes and how many.
Also thinking of doing a bulk buy for a drift tyre ( not sure what that is exactly but assumed that you would need some cheapies to flog the carp out of ) and sizes for them ( assume 17" ? )
Car wash = out :D water restrictions.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
