soooooooo went to see Toy Story 3 today. Movie was pretty good, not as good as the others, but still pretty good.
downside...
walked into the toilet and there was a dude sitting in one of the cubicles DOOR WIDE OPEN, laying some cable, and beating off AT THE SAME TIME
:P:D:blink: :blink: :blink: :blink:
The pig is roadworthy motherf**kers. Rego on Monday n then I get to drive again hoorah! Car is still getting too hot though. its on like 3/4 on the gauge. Radiator isn't blocked but I dunno. The electric fan isn't coming on when its getting too hot though. Ideas?
this shit is amazing
huuuge love brother!
on of my friends joined that, i loled so hard at her
downside...
:P:blink: :blink: :blink: :blink: :blink:
that is quite a significant downside
electric fan is only for the A/C
does it have a clutch fan?
could just be that the gauge is crap too. Wouldn't be the first 31 with a shit temp gauge
its has a clutch fan that is working. I'll have a look at the thermostat/ get a new one and see if that helps. it is definitely getting too hot though you can smell it. 13 hours and 24mins mangs
GET A GENUINE NISSAN THERMOSTAT!!!11!!!!1!!!oneone!!
Srsly, all aftermarket ones for RB30s suck balls and open at the wrong temperature, in fact, that could be your problem at the moment.
huzzah, my internets has ticked over so I'm no longer capped.
Friends 33 kicked the bucket yesterday, was pretty funny because he never maintained it. Downside is I'll probably just get a crate from just jap or something and throw it in, would be easier than having to work out what the problem is and replace it.
We just got capped today for some reason...when we have used the internet less than ever, hmmm seems we have a HAXOR!
That replace the whole engine theory would work...unless of course the issue is with one of the ancillaries and he replaced a whole engine for nothing!
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
