Im in Sydney both of those dates. :down::)
Well done with those letters, well written so hopefully people will perk up to it.
Write to Today Tonight or ACA about it. That would make for interesting TV.
Yeah why not should be good for shits and giggles.
Which Wed (21st or 28th) ?
That's what he's asking. What will people prefer/go to.
I'll change my preference to next wed (28) because i may still be a bit sick this wed
next wed it is the 28 im in for that
PORN LADY UPDATE
Yep she did lose her job.
THE END
luls that is pretty bad
Mangs *tips hat*
out for gemania in for thursdayia
Mang *waves salmon*
These both look damn sexy on me:
But then again so do these ones:
Nobody had these ones for me to try :D
The incredibly hot chick @ sunglass hut said I should get the plastic ones, but then wouldn't give me her phone number (even when I had them on) so her opinion is no longer relevant.
They are that cheap on eGay I might get one set of the wires and one of the plastics...
sunglasses
I think Straight Jackets look like sunglasses lebs or terrorists should be wearing and they make white guys look like roid munching asswanks.
I'm not a big fan of the new Minutes, I really liked the old ones though. My vote goes for the Square Whiskers still.
I should get new rubber for my Juliets and wear them again.
Hahaha john i do have a set of Straight jackets..... are you saying im a terrorist? You've got it all wrong though, white boys that look like roid munching asswanks only buy them in white.
An interesting opinion, because I think they are the only two models in the current plastic range that don't look like completely overdone arse-wankery.
Exhibit A, Juliet:
What's with the gay bit sticking out in the corner? FFS, they would be good if not for that. Same deal with the pennys, except they are even worse.
Exhibit B, Jawbone:
What wanker would be seen in those?
Exhibit C, all the rapper/gangsta spec big square shit things:
And all the other models that fit that category too...
And then the half frame ones, I can't stand any of them:
Straight jacket and minute seem to be the only sensible ones left. Agreed though, old minute was much better (as was old straight jacket).
I think I'll definitely get a set of the square whiskers, although I'll sleep on it and decide tomorrow. May get a set of minutes as well for the odd occasion I have to do something sport-like :P
You are a terrorist. And yeah any plastic sunnies in white definitely makes you a cocknugget roidhead
That's where the screw is to hold the lens in. It's stronger having it there instead of being the same one that the arms swivel on.
They're probably the most comfortable sunglasses I've ever owned too :P
The Pennys are smaller than the Juliets that might be why it looks more odd to you?
Edited by Isola
yeah, i've officially re-assesed them, since they are metal and that knob is functional, I like them :P
a little on the pricey side though :) EDIT: And none with black lenses without going "custom" (uleh)
looking on ebay now...
Edited by Smity42
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
