Im in Sydney both of those dates. :down::)
Well done with those letters, well written so hopefully people will perk up to it.
Write to Today Tonight or ACA about it. That would make for interesting TV.
Yeah why not should be good for shits and giggles.
Which Wed (21st or 28th) ?
That's what he's asking. What will people prefer/go to.
I'll change my preference to next wed (28) because i may still be a bit sick this wed
next wed it is the 28 im in for that
PORN LADY UPDATE
Yep she did lose her job.
THE END
luls that is pretty bad
Mangs *tips hat*
out for gemania in for thursdayia
Mang *waves salmon*
These both look damn sexy on me:
But then again so do these ones:
Nobody had these ones for me to try :D
The incredibly hot chick @ sunglass hut said I should get the plastic ones, but then wouldn't give me her phone number (even when I had them on) so her opinion is no longer relevant.
They are that cheap on eGay I might get one set of the wires and one of the plastics...
sunglasses
I think Straight Jackets look like sunglasses lebs or terrorists should be wearing and they make white guys look like roid munching asswanks.
I'm not a big fan of the new Minutes, I really liked the old ones though. My vote goes for the Square Whiskers still.
I should get new rubber for my Juliets and wear them again.
Hahaha john i do have a set of Straight jackets..... are you saying im a terrorist? You've got it all wrong though, white boys that look like roid munching asswanks only buy them in white.
An interesting opinion, because I think they are the only two models in the current plastic range that don't look like completely overdone arse-wankery.
Exhibit A, Juliet:
What's with the gay bit sticking out in the corner? FFS, they would be good if not for that. Same deal with the pennys, except they are even worse.
Exhibit B, Jawbone:
What wanker would be seen in those?
Exhibit C, all the rapper/gangsta spec big square shit things:
And all the other models that fit that category too...
And then the half frame ones, I can't stand any of them:
Straight jacket and minute seem to be the only sensible ones left. Agreed though, old minute was much better (as was old straight jacket).
I think I'll definitely get a set of the square whiskers, although I'll sleep on it and decide tomorrow. May get a set of minutes as well for the odd occasion I have to do something sport-like :P
You are a terrorist. And yeah any plastic sunnies in white definitely makes you a cocknugget roidhead
That's where the screw is to hold the lens in. It's stronger having it there instead of being the same one that the arms swivel on.
They're probably the most comfortable sunglasses I've ever owned too :P
The Pennys are smaller than the Juliets that might be why it looks more odd to you?
Edited by Isola
yeah, i've officially re-assesed them, since they are metal and that knob is functional, I like them :P
a little on the pricey side though :) EDIT: And none with black lenses without going "custom" (uleh)
looking on ebay now...
Edited by Smity42
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
