I really want 4 piston brembos of some description, but yeah might be worth a look if any R34 GTT ones come up for a good price.
Yeah for sure, The R34 GTT ones are almost the same size as a r33/34 in the disk department but up close the calipers of the brembos appear a little stronger and chunkier all round.
I am actually looking at 6 pot brembos from a typhoon, my brother who is a mechaninc can get them very cheap, but then i have to do the sums on how much it would actually cost to fit them
Morning peoples.
Very exciting day here in the office.
Wa
hoo
same here, im literally overflowing with excitement.
Im also waiting to hear if my car has been tuned yet so time is going soooooooooooo slow
Is EFI down near ERD ? I thought EFI was good ? :D
Yes they're near ERD, the road before the drive-in.
Haven't dealt with them before.
And she's not just a facebook troll.
year near ERD, to get Dans warranty on the engine i need to get it tuned at EFI, not that i wouldnt have any way because they did an awesome job on Annas car
hate that, oh that reminds me i feel the need for caffine, should go do somthing about it i suppose
mmmm caffeine is win
Hey Andy, is there still a dude at the EPA called Craig (forget his surname). About 5' 8" dark hair, glasses, bit geeky looking but snappy dresser?
I used to work with him when I was there. Think it was level 6 that I worked on... can't remember exactly as it was about 6 years ago.
I have not met anyone named craig yet, however he may still be here, i know harldy any of the EPA people, its like myself and the guy i wirk with are the foreign embassy of NRW or somthing, surrounded by EPA people but not really connected lol
ahhh fair enough. Bit of a lone wolf, eh? :D
Dan B: I lolled - you may too. In an episode of Metalocalypse - they go to a supermarket called FINNTROLLS :blink:
woot fixed!
oh and for those of you who didnt know yet my car is finally finished! 301kw at 17psi. Very happy as last dyno day there the dyno made a few people sad with 'low' power figures so it should make 300kw at least every where it goes!
Hooah we're back :huh:
Congrats Andy now you need to bring it to Baskins so we can all ogle it. :D
In other news John Deere FC had their first win last night. 4 - 2 :D
Im only scheduled to get it back tomorrow and it is in dire need of a clean (over a year in a workshop will do that to a car) but i do plan to bring it around at some point, maybe tomorroy but if not then defs the next week
Bring it tomorrow and we'll go to the Freedom Car Wash, haven't been there in awhile :huh:
where is that? Annnnnnd i just got told it has a water leak somewhere so will have to wait and see if i get it back tomorrow at all
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
