On Logan Rd near Mt Gravatt. Sucks about the water leak, hopefully it's nothing too serious.
Oh yes, I know the place! Yeah shouldnt be too bad, just another one of those annoying damn things that always crop up at the end of builds
Yeah after being off the road for awhile there are bound to be little niggly problems that crop up.
always! it takes a good month or two before you find them aswell :huh:
Question:
How does one attach a plush toy to the bumper (tow hook) a la drift toy? I finally worked out what I want... but need to know how to attach it!
zip ties FTW
zip ties FTW
yep mine have always been zipped on, or in the case of bigbird on the blue r32 it was wedged in the tow hook in an effort to keep the rear bar on lol
It doesnt have a loop on it? What is it? If it is 'humanoid' in shape go for one around the neck then put one through that and on to the tow hook
one around the waist and then looped to the tow hook. or get your Mrs to sew a cloth loop on somwhere near where the coin slot is!
You want his mrs to sew a loop in her WHAT!!!!
Congrats Andy now you need to bring it to Baskins so we can all ogle it. :banana:
+11ty!!! Great stuff cAndy!
In other news John Deere FC had their first win last night. 4 - 2 :/
Good Job, Team.
We still haven't won a game all season :)
Question:
Zip ties? Wire? String?
zip ties FTW
+1
won't that squish it? :D
Lol, thats f**ked up
If I can find one in the right size:
i wouldnt attach taht if i was you.
thats just cop bait. theyd want to come see their friend dangling off your car and pull you over every 30sec.
P.S. went to work at 7:15 today, got home at 6:15. Fail
P.P.S Noel, where's your f1/33/boat avatar?
Trust me smitz, it will be there just as soon as my bud comes over.
Question:
I had two of those tree shaped air fresheners hanging from my rear bar at some point, but someone stole them :whistling:
Stopped the car from smelling like dirty exhaust fumes though - so if anyone wants to top themself just hang some air fresheners and die in a nice smelling environment.
Actually thats horrible, mental illness is serious business as is the internet.
