your a serb/croat/bosnia none cause the copper was afraid that if he defected you you would remove limbs with your bare (bear) hands?
I think I was in luck because they already had 3 cars pulled up getting inspected, and couldn't be bothere with mine
one of those was a nice maroon r33. personalised plates, ***33 or something like that
hope you did as well as i did
What do the defect stations look like ?
I've been lucky and never seen one.
Traffic was diverted into a car park. Breathalyser setup, with a few spots afterwards reserved for "suspect" cars with cops going over the cars with torches.
About 15 cops there all up
Have seen others with department of transport vehicles in there as well, but never been pulled up in one of those as when I have driven past, they have been on the other side of the road, thankfully.
Wasn't TJR33 with a black bonnet?
@Mangs - Had a look on Thursday night but couldn't see it anywhere. Will bring booze on Thursday.
31 has an oil leak. Stupid piece of shit. I'm guessing it's because it has like 5.5L of oil in the bastard lol. well I'm hoping so anyway. I haven't investigated any further than the patch of oil in my car space.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
