Amen. 32 has 265s all round, once the lips were done I've had no problem with scrubbing :) The 31 has stretch though.
I suspect it's because the wheels don't fit in the guards lol. That and John never listens. Ever.
Oh! Is that all! I thought it may have been because he's fully sic and rad kewl. :)
I cant wait to get real rubber on my car, this cheese cutter tyre onto fat rims thing is gayer than aids, Ima need a good lip rolling first though
225 on 10.5's is not gay
Anyone know any good tyre puncture repair places that don't charge as much as a new tyre would cost?
I paid $35 to repair a tire at bridgestone newstead. Was a pretty wide screw that came out as well
Direct quotes:
Jax "225 on a nine and a half? you're joking? we can't do that!"
Bob Jane "That tyre size is completely wrong. It's illegal. I won't do it. I don't even want it near my workshop!"
Goodyear "...our machine is too old for that"
K-mart Tyre/Auto "how did they even get that on there in the first place?"
I had the same problem with 225's on 10.5's at a place new the valley. Said I was a lair.. So then I took him out to my car.
265/55/18 is for poofs
why would any one use a 55 profile on 18s?
Ok i concede, having the power to bake bicycle tyres with no sidewall give to aid traction is pretty f**king awsome!
No idea. You being a homo I just thought of the most homo size.
And you're not listening to these people because?
because they're having a cry about something that can obviously be done
The wheels fit in the guards just fine. The problem was scrubbing before the guards were rolled. So I bought tyres that would fit, and not scrub every time I looked at the car. Now I have the 225s until I wear them out, and then will be replacing with something slightly larger now that the guards are rolled.
Remember I had to get tyres STRAIGHT away according to My. Policeyman who pulled me over and let me off. So I didn't have time to wait for the guards to get rolled.
I thought that was a given? John is the most hectik bro I've ever met. He even has full sick dose uleh
big <3
that they do, thats why you buy tyres that FIT :O
They DO fit... as long as people actually TRY it instead of just crying about it :P
they should use a 115 15 18 i reckon, then put it on a 13 inch wide rim....would give killer handling and ride!
Its like homer and the deep fried shirt, I didnt say they couldnt, I said you shouldnt :P
but given your desire for larger tyres next time and being stuck with the 225's for now i totally understand your point of view
And who wants to hear today's police story?
Go!
Also Josh did you know we are both in the top 40 posters on this site...so much wasted youth whoring :P lol
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
