Blasphemy!
A minor blasphemy, easily forgiven (We did have a Milton Reformation).
Going elsewhere or some other time and then saying "X was > Green > *" is a different story.
Hmmmmm...... OK then
That would be a keel-hauling offence
In order for X > Green > * a unanimous decision would have to be made by impartial judges after thorough investigation of X. Agree?
NO! X can never > green as long as the one leg is both the same. :action-smiley-069:
A thorough investigation of green and all it's surroundings would also be required. I volunteer myself for all required investigations
f**kin lol Martin. Nice work.
Just had epic argument with tiler/glue seller guy. He's a douche.
I had an epic argument with a builder yesterday afternoon. Apparently windows 7 should be covered under warranty, so when he f**ks it up he can bring it back for me to spend 5 hours fixing and he won't have to pay anything for it. So I put the question to him, if I got him to build me a house and then I knocked a wall down inside it and the house falls down would he have to build it up for me again?
Ah but then if it could be ascertained that the one leg is both the same and the impartial judges ruled in favour then it could be established that X > Green > *. Correct?
I concur. I believe we should organise a committee to proceed with aforementioned investigations.
Finding impartial judges is like f**king for virginity. :action-smiley-069:
http://www.youtube.com/watch?v=7ya-v-jchr0
R34,33,32 review on top gear from way back. I haven't seen this before so maybe some other guys haven't either!
yes colin he did, its currently been sitting in the workshop since monday arvo though with a coolant leak from a turbo line, its almost an engine out job to replace this 4 inch length of hose!
It's not too bad, taxi spray red but generally a clean car couple minor mods here and there, although he wants these modena rims.
Also tell your dad to buy that cortina, and i'll remember to bring some empties for you tomorrow night
Happy Birthday John. Rock on I says
Cheers mangs!
Not feeling the <3 no more..... :(
And
HAPPY BIRTHDAY JOHN!!!!
if you didn't see it due to post skimming........ :action-smiley-069:
Edit: Happy Birthday John! hahaha.
:D
That's the S1 review from the silly fat fucker that Martin and I were talking about.
Not feeling the <3 no more..... :)
And
if you didn't see it due to post skimming........ :(
Didn't see it! Was skimming! Sorry
Mucho thankies and epic <3
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
