Hello all.
how was the weekend? Mine consisted of 'Pain da fens... up, down, uuuuuuuup, dooooooooooooooown......'
McRae - backstreet boosting in an unrego'ed car? noice
McFly - The federal 535 is a pretty quick street type tyre. Don't expect too much from them. Not saying they're not grippy, but they are not a flash tyre. Good to hear that your wheel was fixable.
Mr Marine chronometer - Did you sort out your misfire problerm???
Hello all.
Lol I considered putting the 31 plates on it but then just decided f**k it n went without plates. I want it back on the road now though lol :D
Just spent 3.5 hours inspecting a wall with the engineer. f**kin gay.
No one ever said that these walking gant chart guys were employed for having any relevant knowledge! (including maths, or the ability to read gant charts)
Walking gant chart man just asked why my hours this week were less than last week, when in fact i did 1 hour more :D
Clearly he is deducting hours spent on SAU as non working lol
Yeah PMs are there to make everyone else hate life.
Martin - yes 535s are good street tyres.
I have stolen coil pack 1 and 2 and the loom from your ute. I covered it back up again. Haven't put any other parts into it yet because it 1. may not be the problem. 2. I need a vacuum to get all the leaves out so I can put things back where they came from. and 3. I dropped a screw and need needle nose pliers or a magnet stick to get it out.
Edited by Isola
nah it was sitting there behind the 31, just got moved to mine yesterday, will need to make some time to work on that thing too.....
I have an extendable magnet stick thingo if you need to use it.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
