Hello all.
how was the weekend? Mine consisted of 'Pain da fens... up, down, uuuuuuuup, dooooooooooooooown......'
McRae - backstreet boosting in an unrego'ed car? noice
McFly - The federal 535 is a pretty quick street type tyre. Don't expect too much from them. Not saying they're not grippy, but they are not a flash tyre. Good to hear that your wheel was fixable.
Mr Marine chronometer - Did you sort out your misfire problerm???
Hello all.
Lol I considered putting the 31 plates on it but then just decided f**k it n went without plates. I want it back on the road now though lol :D
Just spent 3.5 hours inspecting a wall with the engineer. f**kin gay.
No one ever said that these walking gant chart guys were employed for having any relevant knowledge! (including maths, or the ability to read gant charts)
Walking gant chart man just asked why my hours this week were less than last week, when in fact i did 1 hour more :D
Clearly he is deducting hours spent on SAU as non working lol
Yeah PMs are there to make everyone else hate life.
Martin - yes 535s are good street tyres.
I have stolen coil pack 1 and 2 and the loom from your ute. I covered it back up again. Haven't put any other parts into it yet because it 1. may not be the problem. 2. I need a vacuum to get all the leaves out so I can put things back where they came from. and 3. I dropped a screw and need needle nose pliers or a magnet stick to get it out.
Edited by Isola
nah it was sitting there behind the 31, just got moved to mine yesterday, will need to make some time to work on that thing too.....
I have an extendable magnet stick thingo if you need to use it.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
