Reel big fish?
The band? :) They're awesome is all you need to know.
are awesome
side note am going to attempt this ;
iCrap 3000
should result in possible awesomeness or epic failure hopefully with lots of fire. Either way
win :(
Keen to try that on my phone. When uni is finished and I have more time to f**k around and break stuff.
lol you should have a "approved by tim" stamp made up
f**k the stamp it needs to be a brand thingy like they use on cattle. :)
Have you tried kicking it ?
Only about a hundred times :(
Sup mangs. Managed to get BDO tickets and Reel Big Fish tickets. Great success :) :)
BDO = same
Didn't know about RBF tix, not so fussed but that's cool nonetheless
Mate the wheel studs are a press fit so you need to push them out not twist them. Have seen it done with a hammer but this isn't the best way because the hits also smash the axle bearing and can cause it to get flat spots on the rollers leading to failure. If your going to do it this way then you should put a nut just on the stud to stop it from mushrooming. The other way you can do it is to use a ball joint remover although have never used one for this. Acording to the manual you can't remove the hub. Unsure as to why but. To reinstall space it out with washers and tighten with a nut to pull it back in. You'll have to remove the disk and pads to do this as well.
Ahh cool cool, thanks heaps for that run down man. The problem isn't getting the studs out, just getting the hub off... but now you've sorted me out :) mallet + stud tonight = win. Someone make a joke about a 'pounding' by a 'stud'. Go on. Dare you.
This should be interesting.
My iPhone has turned to crap after the OS update.
Well, crap turning into crapper crap. Does a double negative make a positive?
Always
Keen.
I don't know if the baskins girls would appreciate getting stamped though...
Wrong attitude. Never question yourself. Stamp, enjoy, run. That's my motto.
Finishing uni is overrated.
f**k the stamp it needs to be a brand thingy like they use on cattle. :(
That would result in damaged baskins girls. Not good.
Not sure about pounding by a stud. That would imply you are a stud.
However, I am sure you have pounded a stud or two in your time :)
Always
*APPROVED*
keen for stamps, stickers, fire, baskins and jb!
*APPROVED*
cbf quoting
Scott: wtf did you unplug? my slip light is on all the time now!
Ranga+Ravi: congrats on the BDO tickets! I decided not to go this time around =/
John: glorious win on the Grace approval... but you're hiding your wall posts?
Martin: keen for bathurst+f1+drinking if something is happening
im just goin to drink
oh ravbat, your 33 still for sale? my work mate will be looking for a 33 soon, so i'll point him in your direction
Edited by Dan_B
In the fiction section
LOL
I bet the people who said "I'll wait for the movie" were totally over it by the time it came out.
Double lol
cbf
Triple lol
You can find that one by going to the baskin's wall.
Definitely needs MOAR Grace
Doesn't look promising :P But I'll let you know
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
