The cheapest one I've seen was 13K
That's what has me reconsidering as well as the issue of availability of standard replacement and aftermarket parts
I remember when I used to hunt for parts for my 205 gti, everything seemed like it was coated in gold. had a quote for $900 for a new set of radiator hoses. for rubber fucking hose
hence I will probably end up buying one of the old mustang shaped celicas and have fun with that.
The only thing I don't like about them though, is the engine bay is not as generous as in the 240z
Sink another 20k into the GTR. The depressing thing is 20k doesnt go very far lol.
I'd imagine it would make it a nice streetable GTR, I have no idea about the cost of parts on those though.
im actually the same as Martin, I would like another 20k to sink into mine for brakes, new suspension, track rubber, carbon bits and maybe some bigger turbos :mrt:
Word for word excactly what I would do. :D
Great minds think alike, and scrap bigger turbos, If i was going to upgrade I would go for a 35r, tried and proven....by you!
A great story for sure.
They will all get pots of money too for selling their story to the media
there isnt enough money in the world to entice me to go through that soit.
I hope they make huge bundles from it.
If you told me in advance I was going to be stuck in a cave for ~65 days and make a few million dollars I would do it in a snap.
If you told me there was going to be 32 mexicans in the cave with me I'd probably make you double it :)
But yeah, being stuck down there and not knowing when/if you will ever get out would sure suck. Definitely hope they all make good coin.
In other news, Duke Nukem Forever might actually be released?
http://www.news.com.au/technology/is-duke-...0-1225938292750
F*CK YEAH XF! Duke FTW!
Gearbox are the perfect company to do it too, it might actually happen this time :ninja:
and wasn't there one fellow who had his wife, mistress and possibly a third girl waiting for him to be brought out.
The wife wasn't there when he surfaced, the mistress was. :ninja:
WinRar!
what the hell are you guys talking about? :)
Come out from under your rock
Deep Holes and Dirty Mexicans
*Stamp* APPROVED
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
