Apparently the peak is 2:36 now, they keep changing the goal posts lol
Water didn't look high at all at 12:30... mind you i am down at Murarrie
Miso - where did you get your tartan handbrake/shifter boots from and would you care if I rocked them too?
Had them custom made. Think it cost $60 from memory. Have the details of the place that did it somewhere, if I have a look around
Have plenty of material left over at home if you want to use it.
Sink another 20k into the GTR. The depressing thing is 20k doesnt go very far lol.
Depends where and what you buy, and who you get to do the work.
20k could get you a seriously fast 32 GT-R even if you started from stock, but as you already have a fair few sweet mods it would go a LONG way.
Think about it, start with a stocker;
sell the 26 bottom end
sell the standard cooler and piping
sell the standard injectors and fuel rail
sell the standard fuel pump
sell the airflow meters
sell the standard turbos
sell the standard dumps and exhaust
sell the standard ecu.
I would think there would be a few grand in all that.
Now, doing all the work yourself you could have a built 30 bottom end under your 26 head with 4wd adapter for 7k or even less I'm sure.
now go buy 1000cc injectors, fuel rail, fuel pump(s), intercooler and pipes, -5 turbos, nice big exhaust system , ECU,boost controller. I've probably left things out but i think that would come in under 20k and you would have a 400awkw GT-R.
Mind you this would be ghetto spec modification.
Edited by Nee-san
Oh I'm sure I could make 20k stretch a fair way if I wanted and you will find some bargains along the way. The problem is then that you now have a 400kw gtr with standard brakes and suspension and I could easily eat up another 20k there lol
I'd be content with just having the gtr back on the road again. Fit the new front pipes and get decent cat and some new brake rotors n braided lines.
If you could find the details of the place for me that would be awesome. I thought they were an 'off the shelf' type of thing. If they're custom I'll see if I can track down some of my family tartan to make them out of. If not I'll find something else epic to make them out of :D
Morning Mangs,
John and Noel, you missed epic-tits-arse-legs-body redhead girl that came in for ice cream, wearing skintight black workout gear of some sort that left almost nothing to the imagination. She single handedly made up for all the fail from the rest of the night, especially when she bent over :D. Oh, and she was a P plater.
TFIF. I should be able to go home around 1:30 :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
