Plan A:
There is a Nandos at Kenmore near the maccas.
Plan B:
sounds good to me. that general area suits me well
once again, near st lucia coles is quiet good as well, as there is a fair bit of eye kandy walking around at that time too
Plan C:
There is a Coldrock/ 7Eleven/Dominoes/Indian in Kenmore.. about 1 minute from Baskins
Vote now or forever hold your peace. Single vote, A, B, or C. Results will be tallied to determine the final destination.
Legitimacy is doubted as website states it was never on maps, and that it was only known as Teneriffe since 1975 when it was actually called that since the 1860s. And that it's postcode is 4006. Australia Post lists a postcode of 4005. Too many alarm bells for me.
ABC Reference
City News Reference
Plan A:
Plan B:
Plan C:
I vote B :verymad:
is there any food stuffs near the st lucia thingy mabob? If so keen for that. I don't really care lol.
Me either. I just didn't know what was down near where Miso was taklin' 'bout. That's the only reason I voted A over B. C was never an option.
Morning mangs.
What an underwhelming response...
My preference is C... but I really couldnt care less if it is one of the other ones.
Looks like C is winning at the moment, any more votes?
Edited by Smity42
Hey guys.
So much bantering and lol's at Johns.
Prob wont be at the southside meeting tonight or the *to be determined* Thursday night meet. Looks like I'll be doing an overnighter in Rocky for work...Why do they always fall on Thursdays?
C it is then. If it's shit we can try option B next week.
Arright, sounds good to me.
Meet HERE at 7:30PM.
John, There looks to be at least two coffee shops there for you :verymad:
Anyone else coming to that southside meet tonight?
Negative, Boss is over from Perth looks like he's shouting dinner.
Hey guys.
Sucks to be you.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
