So, here this Thursday night?
Yep, that's the one. We'll give that a try and see how it goes. If it's no good, we'll keep looking :)
yeah why not lol. We need to find a better permanent place for it though.
The only way we'll find a good spot is to keep trying.
PS looks like they're trying to start up Milton maccas meets on Wednesday nights again..... I remember when that used to be cool.. then the millions of defect raids happened :)
Martin you're terrible
That's what she said ;)
I'm keen for Taringa HJ's... the question is: skyline or laser? ;)
That's a no brainer.
The answer is as clear as a priest sitting atop a mountain of sugar.
Pass
You are familiar with the Spanish saying, he who talks with one hand clapping greases the squeaky wheel, no? I think it's clear which side of the soup the toilets are.
QUESTION:
For the same money would you go for a 4pot AP racing kit with 330 x30mm rotors or the 8pot Ksport kit with 355 x32mm rotors?
Never heard of K-Sport, so for teh alfa I'd go with the AP racings....
For a heavier car though, the extra size and pistons might be good, so I'd research Ksport more :P
Ksport is the same as G4 D2 ect ect, those generic cheap 8piston things that are all over the internet
Plenty of people have used them but I dont know how much benifit i would get from the bigger gear..if it is of lesser quality
I did have R33 Brembos on my old gtst that worked really well hence i am considering the APs which are exactly the same sise rotor but with a bigger pad as the brembos, but like you say the GTR is about 150kg heavier than the gtst i had
i didnt get home til like 4am, so figured it was best to flag :P
holy ballzzz!
im in library now for finance 2 exam on thursday - such a kick in the nut sack
Gluck playa !
I clearly need to be taking whatever drugs you're on. Gimme.
Now explains?!
bring the skyline and we'll help you color match the bonnet :P
No need to :)
Now explains?!
No need to :P
Priest and sugar = black and white. Fairly self explanatory.
The other one was just for the lols.
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
